Tune for shifting Help!!!
Old Nov 13, 2007 | 01:13 AM
Midnightnova's Avatar
Default Tune for shifting Help!!!
I have hptuners and I have not recalculated my gear ratio to correct my speedo. Here is the problem I hit the rev limter on the 3 to 2 down shift when i am cruising at freeway speed almost like a netural but this does not occur at a lower speed it shift fine so far. I was wondering if i did not correct my gear ratio am i having a conflict between my full trottle shift speed VS. full trottle shift RPM? and would correct my gear ratio fix my problem. Thanks for the help.
Old Nov 13, 2007 | 09:41 AM
Ed Wright's Avatar
9-Second Club
Why don't you just correct your speedometer? Depending on which way it's off, that could be your problem.
Good luck, Ed
Old Nov 13, 2007 | 09:56 AM
69LT1Bird's Avatar
If you know you have a problem (have setup the computer for your car) why not fix it before asking a question about a problem that may not even exist.
Old Nov 13, 2007 | 10:21 AM
Default Thanks
Thanks for the help i should have tried that first!!
