LC1 wiring question
Old Nov 14, 2007 | 11:14 AM
RZRSEDGE's Avatar
Default LC1 wiring question
On the LC1, does the black calibration wire always need to be hooked up? I'm wanting a self contained system to move from one car to another and don't see how to do that with the momentary switch and LED wired into the setup. I was thinking of putting a quick connect on the wire and having a box with the switch and LED in it that had a wire running out with an alligator clip on it to ground when it's time for calibration.
Old Nov 15, 2007 | 08:54 AM
Eurospec2's Avatar
You dont need to hook it up, when you want to calibrate (which should be every use on a portable) just power up the LC1 controller without a sensor plugged in, then when you power up the next time with a sensor in it will re-calibrate itself
Old Nov 15, 2007 | 09:45 AM
RZRSEDGE's Avatar
Thank you much!
