po1153 code
Old Jun 19, 2003 | 01:36 AM
z-ya's Avatar
Default po1153 code
I have slp long tubes and set this code every now and then.
Usually when idling or on initial warm up.Replaced both front o2's which cured the problem for a week.I have inspected the wiring and found no defects.Any one have a fix?
Old Jun 19, 2003 | 08:44 AM
Camaroholic's Avatar
Default Re: po1153 code
What kind of wiring extensions (if any) are you using?
P1153 is passenger's side, insufficient switching on front O2 sensor. Could be an exhaust leak, bad O2, or bad wire.
-Andrew
Old Jun 19, 2003 | 10:36 AM
Catskynr's Avatar
START HERE
AND HERE
AND HERE TOO
Old Jun 19, 2003 | 09:00 PM
z-ya's Avatar
Fuel trims are slightly negative,wot is rich .960
if i go leaner it detonates.O2 extentions came from ramchargers.It did not do this for the first 3000 mi after header install.???
Old Aug 27, 2004 | 09:51 AM
Bill Bowling's Avatar
Originally Posted by Catskynr
Those links are no good..
Bill
Old Aug 27, 2004 | 11:14 AM
samz28's Avatar
i disabled the code. I watch the values heat up, im guessing the o2 is just getting crusty
