Programming the LC-1 for EFILive
Old Nov 19, 2007 | 01:18 PM
Haans249's Avatar
Default Programming the LC-1 for EFILive
Hello All,
I'm rather confused as to how to program the LC-1 as far as the relation to voltage and AFR goes. In the tutorial provided by EFILive, they say to look in the sae_generic.txt calibration file to get the voltage to AFR relation, which is 0volts = 10AFR and 5v = 20AFR, but then a few lines further down, it tells you to use .88333 volts = 10AFR and 4.21667 = 20AFR, so which one do I use for the LC1? I'm just confused, because now I have two LC1's, and one LC1 seems to be sweeping through the AFR range a lot more then my other.
Thanks.
Old Nov 19, 2007 | 05:23 PM
Haans249's Avatar
Anyone?
Old Nov 19, 2007 | 06:48 PM
shoemike's Avatar
you must program the analog outputs in the LM programmer software
just like this,
Old Nov 19, 2007 | 09:14 PM
Haans249's Avatar
Yea thats what i did. When powered up and fully warmed, one LC1 was outputting a 4.21 voltage, and the other 4.12, so I have to account for that voltage offset of the other LC1 by changing the 4.21 programmed into it to 4.12 and then check the lower voltage as well, correct?
Thanks,
Adrian
