LS1 Edit & Moving PCM to Different Car
Old Jun 20, 2003 | 12:35 AM
Ed Blown Vert's Avatar
Default LS1 Edit & Moving PCM to Different Car
Since LS1 Edit locks to the PCM. Can you move the PCM to another car??
Old Jun 20, 2003 | 11:55 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Re: LS1 Edit & Moving PCM to Different Car
yes
edit: Of the same year since the wire harness changed at least once. If you check the pin outs and everything is the same between the two years you should be fine.
Old Jun 20, 2003 | 12:37 PM
My friend is getting rid of his car, so the plan is moving the PCM from a 2000 M6 to a 99 A4.
Old Jun 20, 2003 | 03:36 PM
AzzHauler's Avatar
Hmm different year and tranny. I dunno if that will work. Maybe try the ls1edit mailing list, http://www.ls1edit.com
Old Jun 21, 2003 | 11:55 PM
Made a mistake, his PCM was from a A4. But we went ahead and tried it anyway. Works fine. Now I can use LS1Edit.
Anything different between the years in the PCM?
