brake light/abs inop
Old Nov 23, 2007 | 10:10 PM
FlyRydes's Avatar
Default brake light/abs inop
My brake light and abs inop lights are on is there a reset. I had a broken frontbrake line and lost all the fluid at on time but re filled and r bled the system but lights are still on
Old Nov 25, 2007 | 03:37 AM
oneBADDz's Avatar
Did the light come on when the front line broke? Check the sensor on that wheel, you might have damaged it or you might just need to clean it up and clean out the connector from all the brake fluid.
