Histogram help
Old Nov 24, 2007 | 07:45 PM
firehawk618's Avatar
Default Histogram help
If I post a histogram would someone be so kind as to look it over and suggest to me where I might make tweeks to improve things..... This is from a drive several weeks ago but nothing has changed since then and today's dyno run.
Here's dyno results and below that is attatchment of histogram.
Thanks for anyone's help / time in advance.
File Type: hpl
Old Nov 25, 2007 | 11:44 AM
Russ K's Avatar
Your LTFT's are lean above 50KPA. I see that your using the default .cfg file. I have a Maf tune .cfg file that you can use for tuning the Maf, but this site doesn't allow .cfg files. Post your question on the HP Tuners forum.
Russ Kemp
