MAP setting
Old Nov 29, 2007 | 05:22 PM
GFORCE1320's Avatar
Default MAP setting
I have my MAP set at 100, when I spray, I'm hitting 105 MAP in the VE tables.
Should I change the MAP setting to 105 or just leave it?
I couldn't figure out why I was running so rich on the bottle, turns out I'm hitting in the 105 MAP cells in the ve table and I never used those cells when running n/a and the #'s were too big.
But the MAP thing I'm not sure about, might not be anything to worry about.
Stock setting on the MAP is 94, I had to raise to 100 because it was pegging it at WOT and going into limp mode. I'm going over it again but it doesn't seem to mind.
Old Nov 30, 2007 | 12:33 PM
GFORCE1320's Avatar
Okay.. I guess I'll just change it anyways and see what it does.
