Deciding on tuner...have some questions
Thanks in advance
A WB is basically a very accurate oxygen sensor, that you can integrate with your scanner to tell you what your air fuel ratio is.
It works off a 0-5 volt reference, as opposed to your narrow band 02s, that your PCM uses, that work off a 0-1 volt ref. WB is much more accurate.
