Is my pcm fried
It cranks but will not fire. I have had more problems with this damn PCM it is the only thing that I can think of. The check engine light will stay on for a couple seconds after I turn the key off. Not sure if that helps. I would post my bin file for you if I knew how.
[Brake] C0055 - Steering Wheel Position Sensor Signal D (Current)
[Restraints] U1000 - Class 2 Communication Malfunction (History) (Immature)
[Restraints] U1016 - Loss of Class 2 Communication with VCM (History) (Immature)
the car crank but would'nt turn on untill i found the ground wire behind the
driver side head broke off the metal tab i reconnected it and the car started
good luck brother
