Torque management; please explain/help...
Old Jul 6, 2003 | 12:52 PM
AZ Power & Sound's Avatar
Default Re: Torque management; please explain/help...
what about on a dyno? fronts arent spinning... could this affect a dyno run then if its still enabled on a M6 ?
Old Jul 6, 2003 | 10:30 PM
Jpr5690's Avatar
just to add to this according to a couple top engineers that were interviewed in gm high tech deleting torque management is one of the most common and biggest mistakes you can make in a fbody these engineers were guys like brian reese from slp so id assume they have the final say in the issue
Old Jul 7, 2003 | 12:36 PM
FASST's Avatar
How is the PCM determining tq? How does it know that I'm not running stock H/C? Does it just assume that a certain amount of fuel coincides with a certain power level?
Old Jul 11, 2003 | 07:23 AM
Black LS1 T/A's Avatar
Moderator
Hmmm...
Before raising the Max Torque threshold, each time I shifted a gear, the power drop was so dramatic, it was like I let off the accelerator at each shift... the nose of the car came down, and the guy beside me (just so happened we were neck-and-neck) gained on me.
Other than the fact that it is harder on the tranny (we know power is), what was their issue with deleting Torque Management?
Old Jul 12, 2003 | 11:42 AM
ChazLS12002's Avatar
WHAT DOES THE PREDATOR DO TO THE TORQUE MANAGEMENT
