Questions about handheld tuners
Old Dec 23, 2007 | 01:51 PM
wait4me's Avatar
did you cap off the air pump holes and egr holes? if not that could be the reason also.
Old Dec 23, 2007 | 01:55 PM
NotthisSS's Avatar
i capped off only one hose and put high temp atv around it. Are ther more than one? That would be causing me a huge vaccum leak huh?
Old Dec 23, 2007 | 04:28 PM
RedTtop6spd's Avatar
Originally Posted by NotthisSS
i appreciate all of your all's help. I think i will probably purchase the EFI Live. It seems the majority of people i have talked to like it best. I will check my coil packs and o2 wires and see whats up there. Once again thanks for the comments and advice. Ill let you all know how all turns out. Thanks.
I would definitly spend a little time doing searches on here about both EFI Live and HP Tuners. They both are easy to use and both effectively do the same thing. Whichever one person decides to buy, they're convinced that it's the easiest and best with the best options. Go to both sites and see which is going to offer you the best extras for what you want to do.
