Abuse mod ?
Old Jun 29, 2003 | 08:40 AM
LS1 PWRD's Avatar
Default Abuse mod ?
I have made the suggested changes to the transmission regarding TM with LS1Edit but I can find any reference to that "Abuse Mod" window. The RPM is set to 4700 and that is about where the tranny is shifting.
Is it safe to modify the settings in this window?
This is on a 2000 Super chicken by the way. It turns 13.3 but we know it can do better with a bit of tinkering.
Thanks for the replies.
Old Jun 30, 2003 | 01:57 PM
TheDogofWar's Avatar
Default Re: Abuse mod ?
Abuse mode,
it's under the ignition tab under engine calibration
Don't know what this is supposed to do for you though. I thought nothing as far as performance. ???
Old Jun 30, 2003 | 04:28 PM
LS1 PWRD's Avatar
Thanks for the reply.
I made the suggested changes in the engine calibrations but for some reason it is not shifting as high as it used to and that window when you first open the transmission section has me thinking.
I will ignore it for now and try raising the MPH a couple of mph and see what that does.
Thanks again,
Neil
