Anyone with similar mods and LS1 Edit inside please
1. Jet hot headers and y.
2. Fast Joy Ram Air.
3. Deck lid.
4. Patriot stg 2 5.3 heads 10.5 comp
5. Comp Custom. 220/220 .581/.563 112 lsa
6. Asp pulley
7. LS6 intake
What are the settings on your pcm using LS1 Edit. I figure if your close its a starting point. Thanks a lot fellows.
7.
http://ls1edit.slowcar.net/files.html
Your cam and headers are the only mods that you need to tune the PCM for. Your AFM is probably rich due to these two mods, but there are several PCM tables that need to be carefully adjusted to get things in line.
