Need some Tuning Advise???
I am trying to tweek my LT-1 (383) setup and need some advise on the following TunerCat tables:
My setup is a CC305 cam, AFR 195 heads, 30# injectors, 58mm TB, mid headers, etc...
The columns I need advise on are:
%Change to Fuel/Air Ratio Vs. RPM at WOT
%Change to Fuel/Air Ratio Vs. Cool. Temp at WOT
MAF Sensor Calibration Tables (1-4)
I am pretty knowledgeable with tuning, however I don't have access to a Wideband O2 and am trying to save the 500+ bucks for a complete dyno tune. What I am looking for is some recc specs for these fields with this Cam and setup as all I have found is a 383 .bin file for the CC306 cam and these settings probably won't work. Any suggestions?
Thanks!!!
