Need to reduce timming with LS1 Edit - How?
Old Jul 3, 2003 | 05:52 PM
IRVINEWS6's Avatar
Default Need to reduce timming with LS1 Edit - How?
I am getting a lot of knock between cells 6-14. Where do I go in LS1 Edit to reduce (spark retard)timming? Do I go to high octane spark area?
Can I just reduce the whole table?
Thank you!
Old Jul 5, 2003 | 04:02 PM
Ragtop 99's Avatar
Default Re: Need to reduce timming with LS1 Edit - How?
you could reduce the whole table but that would hurt performance in areas where your timing is fine. ATAP and find out at gm/sec MAF flow you get the knock and fix it on a more surgical basis.
what are your coolant temps when this happens? maybe a 160 t-stat and matching fan settings would cure your problem.
