PLEASE HELP!!!! TUNING
Old Jul 3, 2003 | 08:50 PM
BLK00TA's Avatar
Default PLEASE HELP!!!! TUNING
I JUST HAD HEADS CAM INSTALLED ON MY 2000 WS6.WELL WHEN THE PLACE TRY TO HOOK UP LS1 EDIT TO TUNE IT IT DIDNT WORK.THERE IS NO POWER GOING TO THE UNIT.THE RED LIGHT DOESNT EVEN BLINK AT ALL.WHAT COULD THIS BE .ALSO THE CAR IS RUNNING LIKE **** AND SEEMS NO FASTER THAN BEFORE.WHEN I WAS DRIVING IT HOME THE CHECK ENGINE LIGHT STARTED TO BLINK??ONCE I GET EVERYTHING FIGURED OUT IT SHOULD BE A LOT QUICKER RIGHT????????????????
Old Jul 3, 2003 | 11:41 PM
SS SLP2's Avatar
Default Re: PLEASE HELP!!!! TUNING
Check the cig lighter fuse as the OBD plug get power from this fuse
you need to do a lot of tuning after installing H/C, as may be running worse now
be sure and change missfires,as cam will set a lot of missfires
good luck Johnny
