P0101 after head swap
Old Jan 13, 2008 | 07:07 PM
dubrado's Avatar
Default P0101 after head swap
Threw that code after the head swap...couple Ideas on what could be wrong
Let me know if this sounds like the problem
Leak on the intake manifold, causing the MAP and MAF to act funny, throwing the code
Or maybe the car needs the MAF tuned, recalibrated.
Car is 04 GTO A4, w/ 224R and 243's w/thinner gasket.
thanks in advance.
Let me know if there is something else it could be.
Old Jan 13, 2008 | 07:16 PM
dubrado's Avatar
and Maximum Delta values were increased to see if that would fix the problem...still throws the code....Also cleaned the MAF and tried a different MAF and still the same code.
gonna check the intake gaskets tomorrow and see, please post if there is anything else I can check...until then I guess I'm stuck on the SD tune.
Old Jan 13, 2008 | 08:30 PM
2xLS1's Avatar
Do you have a scanner to monitor MAF activity? Check the Eng Sens fuse if there is no activity.
Old Jan 13, 2008 | 08:36 PM
dubrado's Avatar
My friend has HP tuners and the MAF was active...we could see the different Hz...and etc...
Old Jan 13, 2008 | 08:38 PM
2xLS1's Avatar
What did you change the Max Delta values to?
Old Jan 13, 2008 | 08:42 PM
dubrado's Avatar
we multiplied the numbers by 4 or so, can't recall off the top of my head, and I'm not at my friends house where the software is.
like you had mentioned in another thread of mine.
I'm thinking there might be a vacuum leak somewhere...what happens is that
the idle in drive is ok...but idle in park starts high but eventually comes down to normal.
Old Jan 14, 2008 | 06:20 AM
dubrado's Avatar
bump.
Old Jan 14, 2008 | 08:17 AM
edcmat-l1's Avatar
Post the tune and run log. Did you ever get the lower end of the VE dialed in?
Old Jan 14, 2008 | 04:53 PM
dubrado's Avatar
not really, seems to run ok, but not that great....stumbles once in a while...idles high, etc...
I'll try to get the logs
Old Jan 14, 2008 | 04:56 PM
edcmat-l1's Avatar
See if he'll send me the tune. I'll give ya some pointers. You got my email address right?
