Crank relearn
Old Mar 22, 2008 | 01:05 AM
QuickdomesticRacer's Avatar
I'm having some problems with random misfire under load between 2-3500K RPM under normal driving. It clears up when you floor it, but returns right afterwards. Someone said it could be a CPS, and need a relearn? Would this cause this type of issue?
Old Mar 22, 2008 | 05:18 PM
Steve Bryant's Avatar
LS1 Tech Veteran
ssheets,
I just ran across this post and you might look in the EFILive Scan User Manual (do a search and put in the words crank relearn). This information is under the Bidirectional Controls section (see below).
Steve
