bucking
Old Jan 18, 2008 | 01:59 PM
ls1n00b's Avatar
Default bucking
Just got my car back from the shop,did a cam install and now my car bucks on low rpm's,1000-1600 rpms pretty badly.
comp cams
238/242 112.lsa
605/.610
Is bucking tuning related or the size of the cam? this is exactley what the tuner wrote
"With any cam you cannot go below 2000-2200 rpms. Thats the joy of a six speed just downshift.
Old Jan 18, 2008 | 02:15 PM
ryansm1's Avatar
How is your AFR at those RPM? If you are experiencing bucking while lightly on the throttle, I would guess it is running lean.
If it is not running lean, or the bucking occurs when you are not using any throttle and goes away when you apply a small amount, try increasing the throttle cracker airflow for the ranges you are experiencing bucking.
Old Jan 18, 2008 | 04:21 PM
wait4me's Avatar
Bucking is something that can be easy fixed. There are a ton of vehicles out there with much bigger cams that idle smooth and drive just as good as stock.
Old Jan 18, 2008 | 04:40 PM
Frost's Avatar
Backwards on this last part... if the bucking happening transitioning to no-throttle, your airflow is too high, either through the cracker or incorrect idle airflow values.
Old Jan 18, 2008 | 06:15 PM
ls1n00b's Avatar
Is that so? i asked my tuner to retune it and he keeps telling all cams buck and surge below 2000, even the cam i was originally planning on putting in, comp cams 228/230 571 573 would buck and surge regardless..the first cam i had was defective according to the tuner, and he had another bigger put in.
The car bucks off throttle,coming down in the revs and a little while driving, but not much at all. i have to tap the gas or let the clutch in to not hop..the lower it goes the worse the bucking.
just want the car to drive like it used too and not die and buck all over the place. im contemplating just putting my old stock cam back in or taking it to another shop, this has really fucked up my day(s)
Old Jan 18, 2008 | 08:53 PM
Frost's Avatar
238/242 112.lsa
That tight LSA and generous amount of overlap will take a lot of work to get smooth and still idle well with a 6-speed. Your tuner will have to spend a while with it, and may need to keep it more than a day to have good startups as well.
The trouble here, is that the amount of base airflow needed to get a solid idle, and the amount that cause the bucking sit on a fine line... too little and the bucking is gone, but it doesn't idle well; too much and it idles well but it bucks. This is even AFTER your cruise timing has been greatly reduced. If I were tuning the car, I would schedule plenty of extra time to get the driveability right. It really will take a lot of work, and there may be a bit down by 1000-nearly 1200 RPMs that just can't be gotten rid of with a 6-speed and still have it idling. If it is bucking past 1400-1500 or so there is definitely work to do. It would all be gone or unnoticeable with a stalled auto. He could have eliminated most of it when he was working on it, and it may have been great that day, but need some touching up again a few later.
Rather than have it retuned somewhere else, maybe try to get your tuner to spend a little more time with it.
Old Jan 18, 2008 | 09:14 PM
wait4me's Avatar
Where are you located?
Old Jan 18, 2008 | 09:27 PM
wait4me's Avatar
Ill be in houston Texas training another shop on the first of feb. and if you are in that area, you can come over and ill tune it all for free. It will idle at 600 rpms if you want and idle smooth.
Old Jan 19, 2008 | 01:55 AM
ryansm1's Avatar
Not trying to stir anything up, I am still learning.
Mine (G5x3, slightly smaller duration cam than the OP) would buck at low RPM, low cruising speed with no throttle input. If I transitioned from no throttle input to a slight amount of throttle (<5%) the bucking went away, and was also alleviated by some added airflow for the offending RPM.
I never had any bucking transitioning to no throttle, nor with steady throttle input.
Would there be three separate scenarios and causes for bucking (lean at steady throttle, high airflow transitioning to no throttle, and low airflow for steady no throttle)?
Old Jan 19, 2008 | 06:39 AM
Frost's Avatar
Typically the bucking at no-throttle or transitioning to no-throttle comes from too much airflow (though if your timing is stock that can be a big contributor). The base airflow table is always addedI always begin with a good VE/MAF before working on bucking, so fueling is never an issue. FWIW, I have never fixed any bucking by adding airflow or seen any corrected in this fashion. I have tuned a pile of G5X3's on the 114lsa and love them. I don't ever have any issues with that cam at all as far as idle or low RPM cruise, and they always make good power. The cars usually startup and idle on the stock tune once the TB is cracked open. Not to say they don't need work, just pointing out that they are tolerant. It's little brother, the G5X1 or X2 on a 112lsa is much more work.
I'm not gonna disagree, if adding air works for you, it works, but in my mind it would be like adding fuel to a car that swings up and down in OL.
