gear/tire size
Old Jan 19, 2008 | 01:31 PM
daniel6718's Avatar
Default gear/tire size
if i wanna get my car tuned for the 26 ill be running on the street and then run 28 a the track is there goana be a problem? meaning does it shift by rpm or mph? or what
Old Jan 19, 2008 | 03:12 PM
foff667's Avatar
LS1TECH Sponsor
97+ LS1 pcm's use both rpm & mph as markers, not sure about the earlier pcms.
Old Jan 19, 2008 | 04:14 PM
daniel6718's Avatar
im asking about a 99
Old Jan 19, 2008 | 04:25 PM
foff667's Avatar
LS1TECH Sponsor
Then you've got your answer
Old Jan 20, 2008 | 05:36 PM
daniel6718's Avatar
so what id normally its at 6500rpm and 80mph
then i switch to 28's and its 6500 rpm at 86mph
is it goana early shift with 28's?
Old Jan 20, 2008 | 06:41 PM
foff667's Avatar
LS1TECH Sponsor
set your mph low & use rpm as your main marker.
