Big Stuff 3 and Drive by Wire
Old Feb 4, 2008 | 07:50 AM
barkingspud's Avatar
Default Big Stuff 3 and Drive by Wire
So, my understanding is BS3 (or any other aftermarket PCM) cannot support DBW true? I have run into a problem with my build that requires me to go 3rd party unless an external Crank Position Sensor can be used with the stock PCM.
I would rather avoid converting from DBW to cable unless someone has the magic parts list to convert a 2005 GTO.
Thanks for reading....
BS
Old Feb 4, 2008 | 01:22 PM
Is my question completely inane or what?
Old Feb 4, 2008 | 01:58 PM
Shawn @ VA Speed's Avatar
no aftermarket ecu will work with dbw at this time,just put on the cable tb,best and easiest thing to do
Old Feb 4, 2008 | 03:24 PM
That's what I figured. I just need to figure out what parts I need to do the conversion....
Thanks Shawn!!
BS
