No spark please read
Old Feb 5, 2008 | 06:48 PM
71chevellels1's Avatar
Default No spark please read
Im trying to get my 71 chevelle turbo ls1 started. I Have no spark, the pink wires at the coilpacks is getting juice and when i turn the key the pump goes on for 2 secs. Do I have to have a maf sensor hooked up and i also dont have a map sensor hooked up because it broke. Is this my problem? Im using stock computer with wait4me tune and wireharness.
Old Feb 5, 2008 | 07:05 PM
Also on the loom that runs on the back of the motor what is the connector for that is the same shape as a map sensor?
Old Feb 5, 2008 | 07:50 PM
LS1MCSS's Avatar
The connector you are asking about is probably your cam sensor and it will never start without it hooked up. You shouldn't need the maf at all if it's a wait4me tune. You need to connect the cam sensor and repair the map before you try running it.
Old Feb 5, 2008 | 08:39 PM
wait4me's Avatar
It wont start until you hook up that crank sensor and cam sensor and map sensor. Those are 3 important sensors. That one near the bottom needs to be plugged in to the sensor behind the starter.
