Check Guages
Old Feb 9, 2008 | 11:15 AM
ttugboatgreg's Avatar
Question Check Guages
I have a 2000 T/A Auto trans ls1. This morning when i started the car the check guages light was on. All the guages seemed to be in the normal range. any ideas.
Old Feb 9, 2008 | 11:58 AM
2001NBMZ28's Avatar
How much gas is in the car? It comes on for low fuel too.
Old Feb 9, 2008 | 02:53 PM
well I feel stupid. I was going to the gas station this morning. But changed my mind when I saw the light on. I thought something might actually be wrong. thanks
Old Feb 9, 2008 | 03:10 PM
2001NBMZ28's Avatar
Be kind to your fuel pump and try to keep about a 1/4 tank.
Old Feb 9, 2008 | 03:47 PM
ssheets's Avatar
I try to always run on the top half of the tank. (yeah, I've coasted into gas stations too). I try to explain to my wife how hard it is on the pump to run it dry as the pump needs to remain submerged for cooling. It doesn't cost anymore money to drive around on the lower 1/4 empty to 1/4) of a tank or the top (3/4 to full) if you drive x amount of miles and get x mpg it costs the same amount if $$$.
Not only is this better on your fuel pump, it is also better on your tank and fuel system. The less area in the tank exposed to air the less condensation you get in the tank. That's why you should always store your car with a full tank.
That being said, my car is just on the 1/2 mark so I need to run in and top it off again.
Old Feb 9, 2008 | 04:07 PM
2001NBMZ28's Avatar
Ummm...meant to say try to keep it ABOVE a 1/4 tank.
