daytona prototype tuning??
Old Feb 10, 2008 | 10:37 PM
fast377's Avatar
Originally Posted by jkwalkercchs
seriously thats awesome
everyone said with that cam u would need 12:1 or more due to the overlap
These things don't run off stock gm computers either. They use a very expensive Bosch engine management system that allows them to do a little more than we can.
Old Feb 10, 2008 | 10:39 PM
jkwalkercchs's Avatar
well i know im gonna run a professional products intake ported matched to a set of 035 stage 3 heads they have the bigger valves but dont recall size
and a 90mm ported and polished throttle body
so i should be close to hp of what these cars made right??
Old Feb 10, 2008 | 10:40 PM
so maybe i should consider a different cam or a custom grind but hydraulic not solid
i just wanna here a 106 lsa idle tho lol
Old Feb 10, 2008 | 10:45 PM
Alvin's Avatar
That sounds like a really cool project. I'd like to do one of those short stroke LS7's like katech sells (346cid) with a cam in the 270ish duration. I definately think its tuneable
Old Feb 10, 2008 | 10:47 PM
fast377's Avatar
That cam sounds nasty....but so do a lot of others. It all depends on what you can tolerate. If you don't plan on road racing, then there are a lot of nasty sounding cams with better street manners. Like I said that cam will probably need to idle over 1200 rpm. That's not ideal for a street car.
As far as tuning goes...if you know what you are doing, you can tune just about anything. Me...I'm still learning.
To answer your initial question: yes the cam is tuneable.
well this class ran 3.905 bores
if i had the money to buy an ls7 block or bigger i would along with some cncd l92s
Old Feb 10, 2008 | 10:48 PM
well im not gonna road race it i actually thought of putting it in my truck
the one on my avatar lol
so maybe a trex
Old Feb 10, 2008 | 10:51 PM
fast377's Avatar
DPs are allowed up to 4" bore. L92s are budget heads. Lots of better options out there. The Tony prepped AFR 205s seem to be the most favorable (flow outstanding below .600).
Old Feb 10, 2008 | 10:52 PM
well hell the guy i talked to said they were limited to 5liters
fast377's Avatar
so maybe a trex
I know a guy who put an LS7 cam in a 6.2L 4x4...sucker runs GOOD.
Old Feb 10, 2008 | 10:53 PM
fast377's Avatar
They are.
  #32
so with a 4.000 bore what stroke do they run
Old Feb 10, 2008 | 10:54 PM
  #33
yea but a 5.0 in a lifted truck?????
Old Feb 10, 2008 | 11:42 PM
  #34
Frost's Avatar
why on earth would you want to do this?
Old Feb 10, 2008 | 11:47 PM
  #35
because i just stumbled upon the internals for a good price
and i think it would be cool
maybe even economicle lmfao
then i can spray **** tons of nitrous to it and make up for the missing cubes
Old Feb 10, 2008 | 11:48 PM
  #36
GrahamHill's Avatar
A 5 liter in that heavy monster with that duration wouldnt pull itself out of a parking lot.
  #37
o no i plan on another cam not the daytona prototype spec cam maybe a trex
Old Feb 10, 2008 | 11:49 PM
  #38
GrahamHill's Avatar
That cam wouldnt even sneeze with nitrous
Old Feb 10, 2008 | 11:50 PM
  #39
well dam what do u recommend
Old Feb 10, 2008 | 11:51 PM
  #40
GrahamHill's Avatar
Oh ok. That bottom end was made to fit rules for a light race car. Its in no way going to be optimum at all for what your doing.
