a4 tuning question
Now w/the new converter I shift around 6200rpm and 77mph. (I did not touch shift rpm's yet or mph)
I need to up that so I can spray to 6200 and have a couple hundred extra rpm left to go before it shifts.
From my understanding BOTH MPH and RPM have to be met for a shift to happen?
So whichever requirement is met last, will be the deciding factor on when to shift?
A converter should not make the WOT shift any sooner.
The pcm needs to see the mph before it allows a WOT rpm shift, otherwise it will hit the rev limiter.
