speedo problem
Old Jul 15, 2003 | 05:38 PM
work in progress's Avatar
Default speedo problem
Corrected my tire height and now I have a problem. ABS light is on as well as brake light.
29" tire
3.73 gear
apply and now I have the problems. Any ideas?
Old Jul 15, 2003 | 05:45 PM
Cal's Avatar
Cal
Default Re: speedo problem
Go back to the flash version before you made this change and verify that the problem goes away. If it does, try doing it again, maybe you just got a bad load. If that still doesn't work, try corecting the speedo using the stock gear ratio and lieing to the PCM about the tire sized to get it to come out right . . . that's what I had to do. I think there may be a problem in LS1edit relating to this. BTW, I like your avitar!!
Old Jul 15, 2003 | 06:59 PM
thanks
