Disabling LTFT?
Old Feb 23, 2008 | 07:26 PM
Nakoz's Avatar
Default Disabling LTFT?
Ok I am trying to run in SD mode and had a question. If i disable the LTFT's in the PCM would all fueling come from the VE table, including PE?
Old Feb 23, 2008 | 11:08 PM
Frost's Avatar
no, you will still have short-term trims acting. They disable by turning their enable temps up very high in their table. It's the closed loop enable table.
Old Feb 24, 2008 | 12:42 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Also remember that HPT has a table that enables stft in open loop. However, does any of this really have to do with MAF VS SD? You still need to disable the MAF separately.
Old Feb 24, 2008 | 09:25 AM
Rob's Avatar
Rob
Disabling the LTFT's just make tuning that much faster if its already close. You don't have to drive for a long time to get enough data to make some adjustments.
Old Feb 24, 2008 | 04:10 PM
jay_lt4's Avatar
if you turn the closed loop enable temp high you will be in open loop only
you can just un-check the box for ltft enable in the switches section then you will still have closed loop and stft's but the ltft's will be turned off
Old Feb 24, 2008 | 05:21 PM
Frost's Avatar
No kidding, that's what he wants...
With the car going into closed loop, all fueling isn't table based, it's correction based.
