P0171
Old Feb 25, 2008 | 09:21 PM
A-Dub's Avatar
Default P0171
Car is an 03 z06. Headers, vararam, underdrive pulley, and F11 cam. Professionally tuned by a local performance shop. Current issues are P0171 code. O2 sensors have under 1000 miles on them and code showed up before they had 100 miles on them. Both are new.
Tune and scan attached. Obviously you can see the LTFTs are nuts, but what could be causing that reading? If you look at the tune, you can see that the tuner did not modify any of the part throttle fueling. Thats what I am blaming it on. What do you guys think?
File Type: hpt
File Type: hpl
Old Feb 25, 2008 | 10:24 PM
2xLS1's Avatar
I attempted to tune a 02 TA today that had +25% fuel trims. Turned out the fuel pressure at the rail was only 40 psi. Don't always blame the tuner.
Old Feb 26, 2008 | 07:40 AM
A-Dub's Avatar
Yea, that would have been something easy to check.
Old Feb 26, 2008 | 08:50 PM
A-Dub's Avatar
bump....
Old Feb 27, 2008 | 02:24 PM
06GMC4X4's Avatar
My car was throwing the same code, ended up being exhaust leaks.
Old Feb 27, 2008 | 02:36 PM
sprayjunkie's Avatar
Clear it and see if it comes back...for some reason I have seen Vettes throw this code once after being tuned, and after clearing it, it never comes back...
Old Feb 28, 2008 | 10:10 AM
A-Dub's Avatar
Cleared it, came back after 3 driving cycles. It has fresh GM MLS gaskets up top and blocked off AIR fittings. I'm going to have him check for bad welds at the collector
