How much is the license to convert MAF to 2bar
Old Feb 25, 2008 | 11:14 PM
Cchris1109's Avatar
Default How much is the license to convert MAF to 2bar
What is the cost of the license to convert a MAF system to a 2bar setup? What all is done to convert to this? Thanks!
Old Feb 26, 2008 | 12:08 AM
xturboguyx2001's Avatar
u need to get on hpt web site! it should be 2 credits.($100.00) but you should double check. your cable should have been loaded with 6 credits but, that may depend on wich package you bougt. get on the hpt site & have your cable on the ready as it you will need the # on the back of it. set up you acount/ profile & all will be accessable. you may need your app. key too!
Old Feb 26, 2008 | 06:09 AM
macca_779's Avatar
What program are you using? If it's EFI LIVE its free. Read the custom OS tutorial. This basically tells you to full flash a blank Custom OS. Then apply your cal.
Old Feb 27, 2008 | 11:15 PM
98Z28CobraKiller's Avatar
Restricted User
And if it's HPTuners and the car has a 98 pcm, make sure to do a "Write Entire" rather than a "Write Calibration only" which will turn your PCM into a paperweight.
