Code P0443&p0440 Help!
Old Feb 28, 2008 | 05:12 PM
00bluews6's Avatar
Default Code P0443&p0440 Help!
WHAT IS THE BEST WAY OF TRACKING DOWN A P0443 AND P0440 CODE LIGHT JUST CAME ON AFTER PUTTING IN A 255 INTANK PUMP A FAST 90 #42 INJECTORS FUEL RAILS AND A 85MM MAF THE TB DEOSNT HAVE A HOLE DRILLED IN THE FLAP YET BUT IS CRACKED OPEN SO CAR WILL IDLE THE GAS CAP IS CLOSED AND THE EVAP IS HOOKED UP IN THE ENGINE BAY DONT WONT TO PULL THE TANK AGEN BUT WILL IF NEEDED TO FIX THE PROBLEM ANY ADVICE??
THANKS
CHRIS
Old Feb 28, 2008 | 06:29 PM
jay_lt4's Avatar
you will probly be pulling the tank to check the fuel tank module seal, make sure all the evap lines are hooked up
Old Feb 28, 2008 | 07:58 PM
00bluews6's Avatar
ya thats what i thought just didnt no if antone had any subjestions
Old Feb 28, 2008 | 08:03 PM
jay_lt4's Avatar
if it was me, i would just tune out the codes and forget about it
