Wiring differences between 98 and 00
Old Mar 2, 2008 | 02:47 PM
1_bad_ss's Avatar
Default Wiring differences between 98 and 00
I had a 2000 and just bought a 98 trans am. I was going to switch the engine harness and computer and the gas tank from my 2000 into the 98. I believe the dash harness is different also. Do any of the other harnesses in the car have to be changed with that
Thanks
Old Mar 2, 2008 | 03:37 PM
Eurospec2's Avatar
Thanks
You dont need to change the harness, gas tank or anything else, just re-pin the 98 harness for the 99-02 PCM, have the 02 express van fuel segment swapped into your tune with EFI Live, and your done
Give us a call if you need assistance, we are very familiar with the 98 PCM swap.
Old Mar 2, 2008 | 05:32 PM
Frost's Avatar
Thanks
Man, if you already in FL, save yourself some headache and take it to see DOC and Eurospec for the re-pinning.
1_bad_ss's Avatar
I will be calling tomorrow
Old Aug 18, 2008 | 07:42 AM
-Freak-'s Avatar
Any way to swap the fuel segment in with HPTuners?
Old Aug 18, 2008 | 09:06 AM
Frost's Avatar
Email the current file(s) to support@hptuners.com
