what would cause this
Old Jul 21, 2003 | 05:03 PM
peterock98's Avatar
Default what would cause this
My car Threw a code and it's low voltage on the Mass air Flow Sensor
Old Jul 21, 2003 | 06:32 PM
peterock98's Avatar
Default Re: what would cause this
DTC P0102 MAF Sensor Circuit Low Frequency
Old Jul 22, 2003 | 10:24 AM
Catskynr's Avatar
Blown fuse, bad wiring, bad harness
Old Jul 22, 2003 | 11:02 AM
JRcamaroZ28's Avatar
Yep what Cat said. check the Eng. Sensor fuse in the fuse block under the hood (little yellow fuse). if thats not it check the wire harness to the MAF sensor, thats what mine turned out to be. Or it can just be a bad MAF sensor
JR
Old Jul 22, 2003 | 04:16 PM
peterock98's Avatar
thanks
Old Jul 30, 2003 | 05:47 PM
JimMueller's Avatar
How do you replace/fix the MAF wiring/harness? I'm getting intermittent P0102's and I've already replaced the MAF and confirmed the Eng. Sensor fuse is OK.
I had a fake low coolant light issue recently too. Maybe I'll try some electrical contact cleaner on the MAF sensor, that appears to have fixed the coolant light.
Would there be any problems with a <2yr old battery which don't show up on a battery/charging test?
