Fuel system failure
Old Mar 12, 2008 | 06:36 PM
rgemtb492's Avatar
Default Fuel system failure
I just had Jet hot LT's, high-flow cats, off-road Y, and Borla cat back installed. The car ran like a madman when I brought it home. Drove it to work and when I stopped there was alot of smoke coming from fuel pump. Then, it wouldn't start. You couldn't hear fuel pump running. Got it to shop and they said obviously ECU failure. Maybe not completely but, at least to fuel system. They came back in today to dig in deep to find the problem and the car started and ran great. What could be causing this? Do I need to just replace the ECU? Or is it just just something loose in the ecu? Looking for some help here!
Old Mar 12, 2008 | 09:48 PM
OUTLAWZ RACING's Avatar
How in the hell do u see smoke from the fuel pump? its in the tank!!! I think u may have a burnt o2 wire double check everything
