Please help?
Old Mar 13, 2008 | 06:56 PM
Blue06's Avatar
Default Please help?
I swapped a cammed LS1 into my Z71 silverado it has LT,s small nitrous cam, yank 4000, FLT level 4 trans, and 255 pump. Now I'm starting to tune the truck in HP tuners, and have no idea what a LS1 should shift at. Could someone tell me what they shift in rpm at stock, then what I should actually set it to for best performance?? Thanks.
Old Mar 14, 2008 | 05:29 PM
DrkPhx's Avatar
Are you referring to just WOT shift points? The LS1 WOT shifts at 5900-6000 rpms, but a cam will push the powerband higher so you need to adjust accordingly. 6500 rpms is a good starting point (assuming you have the valvetrain to support it).
