Open Loop/Speed Density questions
Old Mar 15, 2008 | 06:53 AM
night ryder's Avatar
RPM, temperature, and TPS only.
Old Mar 15, 2008 | 07:46 AM
Frost's Avatar
It's (alphaN) available in HPTuner's 1bar SD OS with real time tuning on your stock PCM as well.
Old Mar 17, 2008 | 06:33 AM
VH5150's Avatar
Dynojet Fan
I just upgraded to efilive c0s5 and its the *****... I need to start logging my g*kelvin values so I can make a stable tps ve map... I figure its gonna take a while to build up a stable map for that table... then correct it w/ ben factor..
Old Mar 17, 2008 | 08:12 PM
TAQuickness's Avatar
Nicely put. Mind if I borrow it?
Old Mar 18, 2008 | 06:11 AM
VH5150's Avatar
Dynojet Fan
yea when im done w/it... p.s I go by (whytryz06) on the efilive forum...
Old Mar 18, 2008 | 07:39 AM
moehorsepower's Avatar
The OLSD VS MAF is a long ongoing debate, everyone will tell you one is better than the other, I believe one can be better than the other or just preference. It does take time to dial in OLSD. Mine, Forced Inducted with stock maf, 648 RWHP on pump, no drive ability problems at all...
Old Mar 18, 2008 | 07:58 AM
VH5150's Avatar
Dynojet Fan
yes it does take time to dial in OLSD.. I got mine done in like 2 days... If I knew what I was doing the 1st time around it would have been done in a coupe of hours...maby a day just to be sure..
Old Mar 18, 2008 | 09:01 AM
Yup you are right.....................But I am sure you knew a little of what you were doing, or at least understood the principle, for someone that has no idea at all of this procedure, it can be very frustrating and time consuming....
Old Mar 18, 2008 | 12:25 PM
VH5150's Avatar
Dynojet Fan
you are correct...
