3400 stall how much do i up the shift points
Old Mar 15, 2008 | 10:15 AM
lt170chevelle's Avatar
Default 3400 stall how much do i up the shift points
ok i have had my stall in for about two weeks and just curious how much you guys are upping the shift point? i was thinking maybe 5mph is this all that will need to be done?
Old Mar 15, 2008 | 03:13 PM
02WS6FREEBIRD's Avatar
As much as you want, on my LS1 I have not moved shift points, just quickness and firmness and moved my lockup to 4th gear only at like 53 mph so it would not be comming on around town.
Hope this helps
Old Mar 16, 2008 | 11:17 AM
how did you go about adjusting the quickness and firmness? just by line pressure or what? sorry but im a new tuner and still figuring everything out
Old Mar 16, 2008 | 09:47 PM
LS699TA's Avatar
what are you using to tune?
Old Mar 18, 2008 | 11:35 AM
tuner cat
Old Mar 18, 2008 | 11:47 AM
Mike@Diablosport's Avatar
LS1Tech Sponsor
Are you running a turbo with 24# injectors?
Thats gotta be close to the limit of those injectors, even on an LT1...
I would certainly not be raising the shift points till you have more available fuel.
Thanks
Mike
Old Mar 18, 2008 | 12:00 PM
yeah yeah i know i know im working on the injectors
