Help..misfire on one cylinder and tried everything
Old Mar 17, 2008 | 04:29 PM
exploder's Avatar
Default Help..misfire on one cylinder and tried everything
Ok...here is the cliffsnotes version
05 Chev. SSR 6.0 liter
Installed magnacharger with supplied injectors and harness. I have a random misfire in cylinder 6 all of the time at idle, but it goes away under load when driving and at full throttle. Here is what I have tried.
1.new plugs
2.swapped wires
3.swapped coil packs
4.swapped injectors
5.swapped injector extensions
6.sprayed for vacuum leaks with water, and carb cleaner (nothing)
Long term fuel trims for bank 1 and 2 are at +8...O2 sensors are functioning properly, Maf is functioning properly...desired idle and actual are good... what else can I check?
Old Mar 17, 2008 | 04:45 PM
Doc99SS's Avatar
When I had a mis-fire on #6, it turned out to a broken valve spring !!!!
Old Mar 17, 2008 | 07:48 PM
sreve's Avatar
look at the stft and ltft bank 2 while spraying it. if you can pull up a custom data screen for that it will help by speeding up the refresh rate big time. a leak is what i'm thinking you covered the obvious. any freeze frame?
Old Mar 18, 2008 | 08:17 AM
cantdrv65's Avatar
Post
Do a compression and leakdown check.....
