Any way to trick EVAP system?
Is there any way to trick the fuel EVAP system? When I ported my intake manifold I also removed and ground down the evap fittings (took up alot of space) I then filled in the holes with epoxy for a smooth finish. Now the sensor is not sensing any vacuum, does any body know how to by-pass this? (resistor, ground, etc.?)
