A4 Flashing SES Light
Old Jul 24, 2003 | 11:09 PM
ISPEEDWS6's Avatar
Default A4 Flashing SES Light
OK, I'm getting frustrated, I've run into a problem, where i get a flashing SES light but there is no codes or failure records. I only get it at idle like when i'm stopped at a traffic light.After i pull away from the light the SES stops flashing, none of the engine data looks out of whack, so what the hell is it?!?
The Patient is a 02 A4 with heads and 112 LSA cam, small convertor and all the bolt ons. The car runs great even when the light flashes, anyone else have this happen?
Old Jul 24, 2003 | 11:24 PM
speednut's Avatar
Default Re: A4 Flashing SES Light
my 02 m6 will flash ses light at low rpms about 1600 or below on hwy. shop that did head/cam said it was a misfire code due to cam
Old Jul 24, 2003 | 11:40 PM
willyfastz's Avatar
Restricted User
I think thats right ( missfires). If you've got LS1 edit you can clear it right up.
Old Jul 24, 2003 | 11:50 PM
ISPEEDWS6's Avatar
I have edit and am having this problem with misfire turned off. Thats what is so frustrating.
I've even gone back and put the misfire code back in to see if thats what was doing it so i could read it with my tech2, but no such luck... it just flashes at low rpms even after a good tune.
Old Jul 24, 2003 | 11:52 PM
ISPEEDWS6's Avatar
Speednut you should be able to fix your car with a crank relearn, it's an M6 alot eaiser to deal with, this A4 **** is a pain in the ***!
