gear change
Old Mar 25, 2008 | 12:41 AM
daniel6718's Avatar
Default gear change
99 pcm
i was tuned for 3.42 with 26 inch tires...a4
now i changed the gears will it still shift at the correct time and my speedo be wrong or will the shifts be off and not shift correctly?
also i plan to run 26's on my stock wheels and 28's on my draglites...will that affect shift points?
Old Mar 25, 2008 | 12:14 PM
daniel6718's Avatar
ttttt
Old Mar 25, 2008 | 01:12 PM
98FreakZ's Avatar
i think your shift points will still be fine. as for the 28's you might see the shift points want to hang in second.
and your still a ***
Old Mar 25, 2008 | 07:55 PM
wait4me's Avatar
If you change gears on a camaro or ta, you will definatly need to correct the speedo and shifting patterns. They will be off. Only a corvette will get away with it.
Old Mar 25, 2008 | 10:22 PM
daniel6718's Avatar
how am i a *** and who are you?
Old Mar 26, 2008 | 04:45 PM
marovetsm's Avatar
Find a cheap hand held, then you can keep everything correct no matter how often you change your setup.
