BS3 Wiring Shorting
Old Mar 31, 2008 | 12:28 PM
1INSANEGTO's Avatar
Default BS3 Wiring Shorting
As some know the wiring is wayyyyyyyyyyyyy to long. Well talking with alot of people and give a few shops a call I have a clear path forward.
Simple thing is remove pins from connectors and cut to length and replace pins and insert back into connector.
Simple question is where do I find said pins???? I have searched on the interweb and I have came up with nothing.
Old Mar 31, 2008 | 12:37 PM
kp's Avatar
kp
Which connectors? The sensor side is all regular GM weatherpack/metripack terminals, I get them from a friend who works at a chevy dealer but they are available at a lot of places.
Old Mar 31, 2008 | 03:06 PM
Frost's Avatar
Not a sponsor, but google Ballenger Motorsports, they have LOTS of weather pack, metripack and other connectors as well as all of the tools needed to properly work with them.
Old Mar 31, 2008 | 03:26 PM
Phil99vette's Avatar
7 Second Club
Why can't you just cut the wires and splice the harness? Twist, lay over wire, solder and heat shrink. I just did it yesterday with my BS3 harness.
Old Apr 2, 2008 | 01:35 PM
1INSANEGTO's Avatar
Because you increase your chances of something shorting out. I know I dont want to be chase wiring issues so I am just going to cut to length add new pins and push back into the connector and it would but just as if it can like that from BigStuff
When I say pins I mean- Terminals
I am told I can still use the same connectors. However for the cost it might be easier to just get new connectors as some are a pain in the but to remove.
Old Apr 2, 2008 | 01:49 PM
1INSANEGTO's Avatar
Do you think I need to replace the whole connectors? Or just push the pins out cut to length and add new pins and reinsert back into the connector?
Guys at Murrilo said they would only charge like $150.00 to do it so I might just have them do it to save me a headache
Old Apr 3, 2008 | 08:14 AM
SouthStreet's Avatar
The terminal is 12124075 and is available from anybody that can purchase Delphi parts. One example company would be www.powerandsignal.com
Most connectors that use these terminals are pull to seat (push wire through connector from seal side--crimp on terminal--pull terminal back into connector. The little tang that hangs down will key the terminal in the correct position.
