Paging Nic00Z28M6: New Timing Table
"If you notice the timing doesn't actually go up at idle to the regular values in the current tables until it warms up a bit. In the new version of LS1edit that is going to be released there is another timing vs coolant temp table that could possibly be used to give it more timing on a cold start. We shall see."
I believe I have verified this theory by doing a lot of logging with EFILive5. Does anyone know anything about this missing table or when a new release of LS1edit including this table might be out, or if it already is?
Why do you think it will help?? Nevermind-I see (get) it.
joel(Bink)
On another subject, I went to your web page and noticed you've done the LS6 PCV mod. I did this also, but haven't put enough miles on the car to see if there is going to be an improvement in oil consumption. Have you seen any difference yet?
400 rpm values set to 50%,
800 rpm values set to 60%,
and 1200 rpm values set to 70%.
And it still does not start first time everytime, but pretty close.
