lean code on bank 1
Old Apr 1, 2008 | 12:10 PM
RED2K's Avatar
Default lean code on bank 1
I replaced the intake gasket when i installed the ls1. i sprayed around the intake to see if i was getting a leak, nothing happened. Maybe the inner gasket slipped or something. I am gonna pull the header on that side to make sure it is seated correctly. o2 sensor shows active on that side all though it is the original {214k miles} . I am kinda lost at this point to know what to check for. I guess I will pull the intake to see if maybe that gasket slipped like I said but other than that what else should I check? Vac ports or anything else I should be looking for? thanks
Old Apr 1, 2008 | 01:18 PM
Eurospec2's Avatar
If you really have 214k on the original 02's, that would be the first thing i would change
Old Apr 1, 2008 | 01:24 PM
RED2K's Avatar
they show to be working fine but it wouldnt hurt so i will
Old Apr 2, 2008 | 01:33 PM
RED2K's Avatar
ok bought new ones to put in tonight. if that doesnt do it where should i go from there?
Old Apr 2, 2008 | 07:21 PM
styoung's Avatar
i would check the injectors next. that is a possibility.
Old Apr 3, 2008 | 10:59 AM
RED2K's Avatar
ok changed bank 1 o2 sensor and it helped a ton, But bank 1 is still running about 4% higher than bank 2. i cleaned the maf as well. Injectors are new {9k}miles on them
