IAC count down to 12
Old Jul 28, 2003 | 11:34 AM
TheDogofWar's Avatar
Default IAC count down to 12
I'm getting IAC counts down to 12 after it warms up. Is this trouble? I heard 30-50 is best. Do I have an intake leak?
Old Jul 28, 2003 | 11:46 AM
Cal's Avatar
Cal
Default Re: IAC count down to 12
That's OK for an engine that's at peak operating temperature. Whether normal or not depends on what mods you've done to the engine. If you're concerned about an intake leak, get a reading on the MAP sensor; should be around 50 for a stock engine; 40 or so if you have a meduim sized cam. You can use WD-40 or an un-lit propane torch to locate intake leaks.
