How does someone come up with the injector offset table?
Old Apr 3, 2008 | 09:02 PM
Doc99SS's Avatar
Cool How does someone come up with the injector offset table?
I did my search, no methods found. I am assuming the best way is the get it from the injector supplier. Failing that, how would a tuner (like us) derive a suitable injector offset table?
I have purchased the 36#/hr injectors from FAST PN 303600 for my LS2 402 stroker project.
Old Apr 3, 2008 | 09:16 PM
01'WS6's Avatar
With 36# injectors i would imagine that if u just changed the flow rate table then you would be good to go. My understanding is that you really only have to worry about that, only with much larger injectors. Don't hold me to it though.
Old Apr 3, 2008 | 10:43 PM
VH5150's Avatar
Dynojet Fan
^^^ correct, but id like to know the answer as well
Old Apr 3, 2008 | 11:29 PM
cast iron's Avatar
If it's an OEM injector use the offset table from that year PCM (<--What ya'll were referring to?)
For an after market injector, we have them tested:
http://www.yawpower.com/injectordynamics.html
Old Apr 4, 2008 | 05:17 PM
lt170chevelle's Avatar
yeah you should just change it in your table to the size...but was wandering myself with my new injectors if they are to be set at that exact rate they they are rated at
