99 computer with 2001 engine?
Old Jul 28, 2003 | 04:08 PM
1964coupe's Avatar
Default 99 computer with 2001 engine?
hi, i just bought a 2001 LS1 engine but i have a 99 LS1 computer. will i run into any major issues with this computer? i'm also wondering the same thing about wiring harnesses. what other years can i use with my 2001 engine?
thanks in advance,
andrew
Old Jul 28, 2003 | 05:02 PM
Cal's Avatar
Cal
Default Re: 99 computer with 2001 engine?
Don't the '99s have EGR? 2001s don't. I'd just get a 2001 PCM, especially if you're going to mod the engine. I've noticed I have a lot fewer PCM issues with my 2001 than earlier model LS1s do.
Old Jul 28, 2003 | 06:41 PM
1964coupe's Avatar
what about the harness? would a 99 harness work with a 2001 engine?
thanks again
Old Jul 29, 2003 | 01:00 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Yes, the 99 harness will work ok with the 2001 engine. Ideally you would want to reprogram the 99 computer to turn off the EGR (along with anything else you are not using) and match the flow rate of the larger 2001 injectors.
Other than that it will work ok.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
