Two DTcs -- While data logging TPS voltage is -3.4V ???
I am getting two DTCs --- P0101 and P0121. Could the negative volts from the TPS be causing both codes? There seems to be nothing wrong with the MAF. I even swapped in a known good MAF and still get both codes.
What do I do? I am thinking that the TPS is faulty. Is there a reset for the TPS so that it starts at 0.0V at closed throotle?
BTW: I just swapped in an LS2 402 stroker short block.
Concerning the MAF inconsistent readings: I read somewhere that EGR could be bad or I am getting unmetered air (maybe via the EGR).
