running lean under boost?!?
Old Apr 11, 2008 | 03:19 PM
lt170chevelle's Avatar
Default running lean under boost?!?
ok please somebody help me. i seem to be running lean under boost. my ve tables are maxed...am i doing something wrong or just missing something? i am confused on what to do now. got my timing close but fueling is not right.
Old Apr 11, 2008 | 07:13 PM
Old Geezer's Avatar
Regulator boost referenced?
FP rising 1# per # of boost?
Base Fp set at? [Vac line off and plugged]
Wideband sensor readings logged?
Excessive exh back pressure? [Ideally, not more than 2X boost]
High EGT?
Plug readings look like?
Old Apr 12, 2008 | 12:32 PM
John_D.'s Avatar
How lean?
How is the VE maxed, like 300% or something?
Do you know the fuel pressure is good at wot?
Old Apr 12, 2008 | 01:46 PM
ok i had the maf unhooked and seemed to be the culprit. All i have is a narrow band and is saying rich now when wot ,so problem solved. i have my ve tables at 99.6 which is the max i can set them at on the topend and boost areas. Still working on the tune. Any suggestions on usual, boosted ,problem areas would be much appreciated.
