Autometer wideband users in here
I hooked up the red and black wires to a hot and a ground obviously. I left the other wires alone since I won't be doing any data logging. But here is the kicker...before I had the sensor connected to the gauge it would read between 14.7-15.0. Now that i got the sensor and bung welded in and connected to the gauge it still reads between 14.7-15.0. Is this normal or should I be looking into this?
I believe it reads that until the wideband sensor heats up. As there is a heater in the make sure you have an adequate size fuse for it.
You didn't mention if you started the car or not, does the reading change when you do so?
Here is what I'm wondering though. Before I had the connected the sensor to the gauge it would read 14.7-15.0. And now that I have the sensor connected to the gauge it still reads the same? I'll start the car and it will do the countdown and start reading between 14.7-15.0. It just jumps around between that.
Once the car is warm it will switch to closed loop, this used the reading from the O2's, and you will see the AFR reading oscillate around 14:7 AFR, perhaps swinging from 14:2 to 15:2.
The readings you are getting don't sound right. I think you need to look into that further. Have you got a good ground going to the Wide Band guage?
